When pressing enter after typing in the search bar, nothing loads. Have to press enter again.
  • 2 replies
  • 13 views
  • Last reply by og.matt31
When pressing enter after typing in the search bar, nothing loads, the screen stays blank as it doesn't start searching. I have to click enter on it again for it to load immediately. This just started happening out of no where and happens every so often.
Hi
Do you have ZoneAlarm installed on your computer?
Do you have Adblocker Ultimate installed in Firefox?
Paul said
Hi Do you have ZoneAlarm installed on your computer? Do you have Adblocker Ultimate installed in Firefox?
No I don't have either installed. All I have is Ublock origin and TWP - Translate Web Pages.
